A failure occurred when a system component attempted to add a conduit event resource to an internal message database. The sending internal application is notified. It may retry the request after waiting for the resource shortage to clear up.
The system is low on memory resources. The configuration should be reduced in scale or complexity in order for the system to continue operating correctly.
Error
A request to insert event information to a message queue for slots %slotInfo% and pipe ID %pipeId% and conduit ID %conduitNum% failed.
| Name | Type |
| slotInfo | String |
| pipeId | String |
| conduitNum | uInt |
